Some more help with a chrysler 55 hp
eurolarva
Re: Some more help with a chrysler 55 hp
Are your coils mounted the spark plug wire or can they be disconnected. Force went to a different ignition system then chrysler used. Your motor either has the magneto or alternator type ignition. The coil you posted I believe is for a presto type ignition. Check with the marine doctor HERE He might be able to help you better with this question.
