Solvent to remove rtv silicone from maleron fitting
james__12345
I have a maleron thruhull that was installed with rtv silicone that needs to be removed. What solvents that will soften the rtv will be safe to use on the maleron?
dingbat
Best solvent I’ve used with RTV is a knife. Peels right off
james__12345
To clarify the fitting was installed with the rtv and the fitting needs to be removed from the aluminum it's stuck to. Scraping with a knife isn't an option because there's no access.
