solutions starter click, starter will not go up and engage flywheel.
Status
Not open for further replies.
tashasdaddy
the starter has to have a full charged battery, and good cables, clean connections. the bendix gear is driven up by centrifical force, the shaft spinning. 2-3 drops on a light oil, like 3 n 1 oil, on the shaft. bad cables and connections, cause resistance, reducing the power to starter.
90% of starter problems are bad connections. remove and clean both ends of the battery cables, so that they are shiney, also the cable from the solenoid to starter. check for nicks in the cables. and make sure the connectors are on the wire good. the cable tend to corrode from the inside out, if nicked, corroded wires, and connections, heat up and cause resistance to the follow of electricity, thus the starter doesn't get enough. you can also take jumper cable pos battery post to large post on starter. with a good connection, the engine should spin. then if the starter is good clean everything and retest. then trouble shoot solenoid. starters can be rebuit at a starter/alternator shop, much cheaper than a new one.
Be sure the cables area connected to the correct battery post. crossing cables, usually blows the rectifier, and can blow more.
also have the battery load tested at the auto parts store, free, i've had new batteries go bad
Status
