Solenoid not Issue:
tarpologist
Would great appreciate help in running down problem with non started 1986 bass buggy pontoon; Last time to lake turn key and 75 horse Marianer turned over about twice and then acted as if dead or low battery, Have checked battery with meter, have fire to solenoid but not fire on yellow with red ignition wire when key turned to start position. Tried new solenoid, new ignition and know thinking maybe bad ignition wire?? Any suggestions, it done one time before while on lake and when moved thorttle control ensuring in netural it always fired until know.
Thanks
NYBo
Re: Solenoid not Issue:
Welcome to iboats!:cool:
This may be a clue. The neutral safety switch, which interrupts the flow of juice to the starter solenoid or relay if the throttle isn't in the neutral position, may be faulty. You can open the control box and temporarily bypass the switch for troubleshooting purposes.
