eastcoasthd
Thread starter- Joined
- Aug 20, 2010
- 8
I finally got around to installing a Solas 4 blade prop (1413-125-19) on my 2008 Merc 90 ELPTO, ran into a couple of fitment issues.
1. The OEM 21P QuickSilver prop has a bevel on the backside to accommodate the bevel on the prop shaft, The Solas does not?
2. The Solas prop would contact the lower unit housing, i.e. the prop housing would go too deeply into the lower unit.
Standing the two props on their face, side by side, the Solas is apprx. 1 inch taller overall. The OEM prop's hub is recessed 1/4 in. from the rear prop opening. The Solas hub is recessed 3/4 in. from the rear prop opening (allowing it to go to deeply into the lower unit causing interference). Is there a spacer/thrust washer available for this issue? The OEM uses no spacer / washer, or at least not installed in my application.
I called IBoats where the prop was purchased and verified the part #. Solas has no customer service phone# that I could call, only e-mail.
Any thoughts?
Any thoughts?
