Re: "Soft spots on floor"
I'd say keep the boat covered/protected from the elements as well as possible. For example I cant keep mine in the garage, so I cover it with a heavy duty canvas cover which I take off every once in awhile to let it air out.........<br /><br />Try not to let water "puddle" in the boat. If you cant cover it, at least leave the plug out and tilt the boat to allow water to run out. Automatic bilge pump if the boat sits in the water.....<br /><br />EDIT: also if you add anything to the boat like seats etc, make sure u install them properly so as not to allow water to penetrate in those areas<br /><br />Im sure there is lots of advice out there on this one.
