Well, after reading repair articles until my eyes crossed I still have a couple of questions.
I recently bought an '89 21' Supra Bravura ski boat that looked great but had "a little soft spot behind the drivers seat. No problem I thought, cut it out, replace it and go skiing. Those of you with older boats know where this going, I have now removed all the floorboards (deck) both sides (with my fingernails). The two floor stringers on each side, which are about 1 x 6, fiberglassed, are also damaged. The area between the hull and the floor is full of foam.
Ques #1: Is the foam a mandatory item, legal or structual or otherwise? It seem to me that the underside of the floor (deck) can never dry out with that stuff in there. If it has to be there, what is the favored type?
#2: I think I'll just "core out" the deck stringers and glass in a fir 1 x 4 at the top of the remaining fiberglass that went up each side of the rotten 1 x 6. Then lay a piece of glass over the top and down the sides a couple of inches to seal it. Does this seem practicle over completely removing the stringer, glass and all and replacing everything? If I use epoxy resin will there be problems rebonding the old glass to the new stringer?
#3: I bought some 1/2" Marine Plywood to replace the floor. I was thinking of coating the bottom and edges with a couple of coats of epoxy resin to seal it. Then, rather than nailing or screwing (leaks) I was going to thoroughly coat the top of the stringers with epoxy before installing the floor. Then finish the top with glass and resin as originally done. Problems or suggestions?
#4: I agree with those of you who believe that carpet is the beginning of the problem but it does look good so I'm going to hope that the plywood sealing and a conscientious "drying after use" program will be enough. Since the rubber on the bottom of the carpet looks a little thin to be counted on, has anybody had any success with extra carpet glue to help seal out the water from the top of the deck? What kind?
I am hoping to tap into some of your experience (good and bad) and maybe get through this.
Thanks, Rich Fowler
Thanks, Rich Fowler
