Now Im using this(5005ST)and its definitely more of a pain with the zippers and not as stable(falls over if not propped against something). I do however like the storage better.
Flambeau? Tackle Station? 3005ST/5005ST Tackle Bags : Cabela's
Now Im torn if I should go back to the hard box
Ahhh LOL. The thing collapsing when you pull a box is super annoying as well. It almost makes you not want to deal with changing lures.LOL...That's almost exactly the last soft bag I tried,,, mine is an older model, it was laid out pretty much the same though. I didn't like removing a bottom trays and having the top part crush down, making it a pain to put the tray back in. Or, it falling over like you said. Soooo,,, I feel your pain I only used it for 2-3 trips before going back to my old tackle box.
I've had this Plano tackle box for 10-15 years and it's served me well. (Big THANKS! to Plano for sending me 2 replacement latches that broke after 10 years, free of charge.)
I also use these Plano boxes for big striper lures as the compartments are long enough to store 14" lures. Just have to remove all the dividers.
Ive been looking for this but seems its discontinued now
Thanks for the tip! I will check them out.Search under "surf bag". Aqua skinZ make a wide variety of configurations
#85 line on a freshwater setup? That's nuts....on a graphite rod.....it's insane. We use #80 marlin and tuna fishing on penn internationals
The one in the pic is the Flambeau Maximizer Cube. It has 25 compartments. I have the larger version that appears to be discontinued like you said, it has 50 compartments...... I guess technically 100 baits.........
