I recently discovered much to my chagrin that the front deck of my boat is less than rock solid. I could feel it flexing under my weight in the past but never gave it much thought- the fish box is under the front deck and it's hollow under there and I weigh around 250, so some flex was ok, right? Well, after feeling more than I normally did, I stuck my head up into the fishbox and checked things out. It appears that the floor was, (working from the top down) built up using a fiberglass layer, a wood layer scabbed on the fiberglass and then a glass mat layer over the wood. I've seen that style in a lot of boats and it works, but the edges of the mat where it comes off the wood on mine has broken and is allowing the flex. Access is tough but I may be able to sand upside down from within the fishbox. I've never attempted glass repairs in the past and was wondering what would be the best way to reinforce the floor? Can I just run some new mat around the edges of the wood and rebond it to the floor or should I completely cover the wood layer completely? That seems like it will give more strength but will be lots more work. <br /><br /> I don't plan to remove the cap although that would give me excellent access. That's just too extreme for me to attempt. <br /><br /> What do you think?<br /><br />UFM82
