So I screwed up, reversed the battery polarity
TheHammer12
So I went to replace the dead battery in my 1998 Rinker Captiva, with the 5.7 Merc engine in it. Unfortunately I attached the positive cables to the negative terminal and the negative cables to the positive. I got the boat back up and running by removing the insulator in the box fuse on the starter, so now the motor runs, the trim works, and the gauges work, however the radio and accessories, (Horn, Blower, Cabin lights, etc.) do not work. The odd thing is I checked the hot wire at the radio and when the ignition is off I have 12 volts, but when the ignition is switched on the voltage drops to 5 volts, from both the hot wire and the switched wire. Also when I checked the voltage at 12 volt power outlet, which also isnt working, I had around 3.5 volts. Any Ideas as to why the voltage is dropping?
Randy J
Re: So I screwed up, reversed the battery polarity
wild hair guess fried a contact in ign switch?
