Re: so how do i charge my deep cycle battery?
almost retired again <br /><br />The above article is flawed in a few areas.....<br /><br />>To FULLY charge lead/acid batteries,(something most marine batteries never see) one should be specifying current, not applied voltage. Charging with 15.5 volts is a little high ...to reach 100% "state of charge", one must limit the current. (1% of CCA or less, is a safe bet) The voltage at this rate will depend on the batteries condition.<br /><br />>As you say, acid should never be added to a battery. In the case of spillage, only electrolyte should be added. (thats a whole other story...)
