MoparMMatt
Thread starter- Joined
- Sep 10, 2013
- 14
I noticed that the water intake screens were damaged the last time I took out our 1974 70hp Johnson (stinger), and by the time I got it on the trailer the tell tale was down to a trickle. I figured the motor was due for a new water pump at a minimum. When I put it all back together I could not get water to cycle through the top of the motor. Here is the rub:facepalm:, did I
A: turn the fins the wrong way in the pump cup... possibly causing the impeller to not be able to pump water correctly?
or
B: do I have a plugged cooling system?
Having a new handy dandy (part# 506897) service manual im relatively certain I put the new pump together correctly. Any guesses? And are there any troubleshooting methods to narrow it down.
or
