Snap ring pliers for V6 L/U
Walker
What do you guys use. My Matco pliers work fine on the V4 L/U's but are about 1" short for V6 L/U's.
Joe Reeves
Re: Snap ring pliers for V6 L/U
I use the Matco pliers also. Cut the rivet that retains the ratchet locking assy, then remove it. That allows me to use the pliers on any hp model.
rodbolt
hello]<br /> I use a set I bought from snap on or an old set from the OMC tool book that have the extensions on them. the extensions are just over 100 dollars now I think.<br /> good luck and keep posting<br /> I have used the large proto snap ring pliers by removint the red plastic handles and making a set of handle extensions out of 1/2 conduit.
seahorse5
You can use those large pliers from Matco, Mac, SnapOn, etc. and have a welder add about 1 1/2" to the length of the nose. I've used a set like that for almost 25 years and they are still doing fine. The OMC extensions work OK but they can twist if you have a difficult one to install.<br /><br />Aftermarket companies make a similar one. If I remember right, one was Bob Kerr, the company who makes test tanks and motor stands. Kerr's Marine Tool Co, PO Box 771135, Winter Garden, FL, 34777, USA, (tel) 407 656-2089, (fax) 407 656-8633. <br /><br />You can also contact www.precisionmfgsales.com and email them or download the complete tool catalog as a .pdf file.
Walker
I guessI'll cut the locking armoff mine. Thanks guys.
