frustratedboater
- Jul 10, 2007
- 497
Gentlemen,
I had pulled an 85', 351 out of a Mastercraft ski boat last fall to replace the floor and to clean up the motor a bit, due to some rust all over the external engine/trans. It ran real smooth with very responsive throttle before the pull. I gave it a basic break-down while in the garage like: water pump, hoses, pulleys, holley carb, and pulled the cap off the distributor, but left the base of it in. Other than pulling the gas tank to get all of the floor out, that was it. I re-installed water pump, hoses, belts (motor looks real good) and cranked it over. After running the fuel through the line, it finally hit and heard, what I'll try to describe as, ".....rumble, rumble, rumble, pop, rumble, rumble, rumble, pop,..." (that pop sound is coming right under the carb), then repeats... Along with that I am hearing clicking noises as if a bad lifter or an adjustment was needed.
The block was completly drained before winter, I had rebuilt the holley just before install, which had lots of gunk and grime in it. I don't believe it froze or anything. I did replace some of the wires and re-wrapped the electrical harness. I fired it up again and I assumed the timing was off, so I played with the dist., but I still heard the same thing. I know the firing order is correct (checked it about 4 times).
My distributor cap is cracked on the side and ordered a replacement Mallery cap, rotor, points, and condensor. They had the condensor and installed, but same noise. I'm stumped!
Any advice on this one would be welcomed...
