Smokey 25 hp johnson
Clutch102
Hi, i have a 1976 25 hp johnson that started to smoke really bad this spring when it runs. It idles fine, but when you go from about half to full throttle it will bog down and eventually die. The carb has been cleaned, it has good spark and compression, and the fuel mixture is good. Any advice would be very helpful. Thanks!
steelespike
Re: Smokey 25 hp johnson
Choke may be stuck not opening right.Fuel pump diaphram may have a hole.
When it boggs does it still smoke?When it dies will it crank but not start?
What do the plugs look like?
Clutch102
It does'nt smoke as much when it boggs. After it dies it will start back up after a couple of pulls and idle ok. The plugs look ok, they have an oil film on them. I just put new plugs in a couple weeks ago.
