Re: Smokeless oil
I can't believe there is even this much thought/talk about mixing the oil. Just the fuel going into the tank will mix the oil if you add the oil first, and if you add it after the fuel, it will just mix right in almost immediately as soon as it goes in.
I have been filling up on the water and premixing for years and years, pull up I know I'm getting 30 gallons, dump enough oil in for 30 gallons, then put the fuel in. By the time your done putting fuel into the tank and then step off to pay...and the boat bounces a couple times, it's done. Never had an issue in 30 years, even before TC-W3.
