smoke when i run 1994 my 60 hp merc 2 strok?
freedom49
looks like the oil pump,pumping too much oil any body knows how to adjust it?
Texasmark
Re: smoke when i run 1994 my 60 hp merc 2 strok?
How do you know? 2 cycle engines burn oil with the gas so you will get some smoke. Get a can of Sea Foam (auto parts store) and per the directions on the can or 2x what the can says, run through a couple of tanks of gas and use synthetic or synthetic blend 2 cycle TCW3 marine oil. Do that for a couple of tanks and get back.....you will probably find that your problem has mysteriously disappeared.
Mark
freedom49
Thanks mark I will try. Sid
