Smoke from Valve Cover Vent. Mercruiser 165, I/O
sam.thompson
Well I have a little smoke that comes from the valve vent cover when I run the engine at high RPMs.
If it is blow by, should I be worried about water getting into the oil at the same time?
Extensive checks on the oil doesn't indicate I have water in the oil but didn't know if i should be worried at this point if I'm getting blow by that water may somehow be getting into the oil or could.
72 Mercuiser 165, inline 6, I/O
oldjeep
Re: Smoke from Valve Cover Vent. Mercruiser 165, I/O
Why do you think that blow by would cause water to get into the oil? It can cause fuel to get into the oil, but not water.
Ayuh,... Water in the oil is usually a cracked block or heads,....
Blow-by is caused by worn piston rings,...
2 Very different issues,....
bonzoscott
When you say the smoke is at "High RPM", are you getting smoke in the boat while cruising outside of the engine cover? A little smoke is normal but just not sure what or how you're seeing smoke at high RPM.
