Smartcraft Installers - Wiring Opinions Wanted
NVAKeith
I am installing a SC5000 System View in my 2002 BW Venutra 210 this spring. The boat is currently stock and has all analog gauges and doesn't have any SmartCraft accessories (harnesses on engine are unused). I intend to retain the existing gauges and will consider replacing them with SmartCraft versions as they die.
From my interpretation of the wiring diagram in the owners manual, the SystemView harness includes two "System Link gauge connection" couplings that I can directly connect future replacement gauges to.
My dilemma is whether I should include one, two, or no SmartCraft junction boxes in my "Main CAN Bus Trunk" harness run from the motor to the SystemView. According to the installation manual, I can run a direct wire from the engine to the SystemView, or I can include a junction box in and the transom and/or a junction box in the console. Initially the junction boxes will not serve any purpose for me.
So, in your experience have you installed the junction box(es) and if so, what have you used them for down the road? Would you install one in the console, transom, or both?
Thanks for your opinions!
