Re: tahoe Q7i questions
I agree with Prince Vailum. I had a hydrofoil first and while it seemed like it helped, I wound up throwing it away. I put SmartTabs on and there is no comparison. Hydros are ok for smaller outboards on light boats, but they are largely ineffective on sterndrives on a bowrider. Go to the SmartTabs and you'll be VERY glad that you did. You won't believe all fo the glowing reports at first, but the very frist trip with them on your boat, well, you'll understand then. They aren't an option, they are essential.
I didn't replace the bow stop roller, but I did add a stainless steel adhesive bow protector. The roller WILL scratch the gel in that area, but the SS plate mounts onto the bow exactly where it rubs, prevents this, and looks very high-end in the process. I think that it was $20.
Another great option is a Keelguard brand bow protector. They sounds difficult and complicated to install, but I put mine on in about 30 minutes. It's another essential item to protect the hull, and is worthy of your consideration.
Good idea for the anchor storage! I keep my 25lb Navy anchor in the small compartment under the sliding seat that covers the step for sundeck/stern access. I have an old beach towel that I have folded a couple of times and placed into the bottom of that compartment. That works like a charm as well, adn I have to trailer my boat at least 1 hr each way every trip. I like your cooler idea, good thinking!
Hey guys, I am ready to install the smart tabs on my '10 Q7i. (lakes are swollen here in Texas (Most ramps closed in Houston area) so it is a perfect time to do boat chores.
I have looked at Rob's videos on the install and what to watch out for (thanks again Rob) and I have two questions;
1-Smart Tab SX pn? Is it SXz10512-90?
2-Both of you guys have had the hydrofoil (either on the Tahoe or Rob indicated it was on another Outboard). Either way, my question is how did you fill the holes on the vent plate? did you use JBWeld? Any advice here would be appreciated.
Thanks again for your contributions on the forum.
Brian
