Smart tabs
mandopickr
Is anyone using Smart tabs on their Key West? If so, did you install them, and can you comment on the ride, and on the placement of the tabs?
mandopickr
Re: Smart tabs
I didn't like the bow high attitude of my Key West 196BR w Yam F115. Initially I changed from the 16-k prop, to a Solas 4 blade 13x15. My hopes were that this prop would increase stern lift in the mid throttle range. It did increase stern lift, but at 5500 rpms.
I found some Smart Tabs ST1290, and installed them. Installation was just over two hours (primarily because I couldn't find my 3m 5200). Test ride was initially with 4 blade. Immediate plane at 1/2 throttle, full throttle. Corrected bow high condition, but speed dropped throughout rpm range.
I went back to 3 blade, again, boat handled great, speed was higher than 4 blade, but below 3 blade numbers w/o smart tabs at 5000 and above.
With both props I could trim out without porpoising. If I did trim out too far, it simply lost grip.
Next time I plan to decrease actuator pressure, to see if speed will increase throughout rpm range. (currently 3 blade: 4000rpm, 24mph; 4500, 27mph;5000 rpm 32 rpm).
I am pleased. I can cruise all day between 4000 and 5000 rpm with the boat at the proper attitude.
As it turns out, it appears that I bought an old set, since my set had a ball joint for attachment to the actuator, and the trim plate bracket didn't have distinct holes. Otherwise, I think it would be consistent with the current model.
