Smart craft guage beeps 4 times
popertman
I'm not sure what to do about this beeping! I have a 2011 mercury pro xs 150. A minute or two after I start it it beeps 4 times. I checked the oil level of the engine mounted res. it's full. I changed the fuel water separator and sensor on the bottoms of it. I have no clue and the marinas can't even look at my boat for another 3 weeks.
popertman
Re: Smart craft guage beeps 4 times
By the way, this all started when I changed my water pump and took it out the next day. I got on the lake and heard the beeping and turned around and went to back to the launch. I changed the water pump because I was getting a constant beep and the temp was rising higher than what it should have been. Which that constant beep went away once I changed than pump. Now I have this beep, beep, beep, beep and an engine symbol.
Faztbullet
Thats usually a engine low oil tank warning....
popertman
Thats usually a engine low oil tank warning....[/QUOTE
I checked the oil and it is 3/4's full. The oil tank mounted by the engine is full too. I even unscrewed the cap and bled the oil while it was running to make sure I had all the air out on the engine mounted oil tank.
Faztbullet
Check th magnet/float as may be stuck in low position....
popertman
I disconnected the 2 leads going from the sensor on the engine mounted oil tank and put a jumper on the leads coming from the motor and it was still beeping. I thought by doing this it would bypass the sensor right?
