Working on a 99 4.3. Just got it last fall. I have already done a TON of work on the engine a including head gaskets. I just replaced the raw water pump. I've had the lower unit off several times working on various things. I bought an alignment tool to ensure a good alignment. I think I'm almost sea Worthy.... But i can't seem to figure out a vibration that is quite evident at idle. I even hear some rattling that seems like it's coming from the rear of the engine. I would have guessed that it was the gimbal bearing but, when i had it apart the bearing seemed ok to me. Any thoughts on what else it might be? Motor mount bolts are all tight. Thanks all!
