Mark42
Thread starter- Joined
- Oct 8, 2003
- 9,334
My Coleman generator is 5000 watt (6250 max), with a 10 hp B&S Powermate motor. It looks like the typical generator in a square tube frame with 5 gallon flat fuel tank on top and two wheels on the bottom.
It also had a "quiet" muffler. This is a muffler that is slightly larger than the hockey puck sized muffler used on 3 hp motors. Far from quiet.
So I replaced it with a B&S Industrial muffler. Its about 10" long in the muffler body, by 4-5" in diameter. With the end pipe threads, its about 14" long overall. This is a great muffler, and really cut the exhaust sound.
Anyway, the sound is not the issue.
The issue is that after installing the big muffler, it ends up about 2 inches away from and in parallel to the fuel line. After 12 years of use, the fuel hose has hardened and cracked. and gas poured all over the garage floor. Not good. The crack was right near a fitting, so about 1" was cut off the hose and that fixed the problem for the time being.
I came up with these long term solutions; 1) replace most of the rubber hose with copper fuel line. It will never have a heat issue. 2) replace the rubber hose with fresh rubber hose and put a length of aluminum flashing between the muffler and hose to act as a heat shield. 3) replace the hose with new hose and worry about it again in 12 years.
Of course, I am not 100% sure the heat caused the hose to harden and crack. The hose could have hardened just from age. Don't know.
Just replace the hose and let it last another 12 years, or upgrade to copper or fabricate a heat shield and hope I die of old age before it needs maintenance again? What do you think?
