I fished a tournament last weekend and just noticed a small dripper seeping out of the prop on my 9.9 Johnson running down the outside of the lower unit. Any suggestions on what the problem is or what I need to do to correct the problem?
Dip a finger in it and see what it is. If it smells like gas (very likely), don't worry about it. Lower unit oil has a strong sulphur smell. If you find that, it's possible you have a seal needing replacement. In any case look for monofilament wound around the prop, and remove any you find.
