small block v8 with a 1.98 ratio sterndrive??
lime4x4
Here is the number off the sterndrive i was able to find it after scraping some paint off 0C383695 before that it's either 1.50R or 2.50R. Then i marked the prop and crankshaft i turned the crankshaft 2 full turns till the prop turned once.So by my calculations that's a 1.98 ratio sterndrive. Which would explain why i have such poor performance out of this boat. So it looks like my only option is to buy a new sterndrive to get the correct ratio.
Bt Doctur
Re: small block v8 with a 1.98 ratio sterndrive??
Or have the gears in the upper replaced with 1.50`s
lime4x4
Which will probably cost just as much as a new sterndrive...lol
Reel Poor
Before you dismiss the drive completely, pull the top off the drive and count the teeth on the two gears, then divide the small number into the larger number just to be sure.
The case, according to you previous post says it's a 1.50:1. If it's not someone has changed the gears in the drive.
180shabah
Replacing the upper gearset is not that expensive, a new drive will set you back at least $1200
lime4x4
I i'm a chevy tech so working on stuff like that isn't a problem.Just don't feel like buying the tools necc to do the job properly..
lime4x4
If i decide to bite the bullet and just buy a new sterndrive which one?
the boat in question is 86 searay almost 27 feet long and probably weighs close to 6500 lbs when loaded.Single 260 hp 5.7 4bbl carb engine The 1.5 or the 1.62 ratio drive?
lime4x4
well i decided to buy the correct upper sterndrive unit.Got one from ses with a 3 year no fault warranty for 665.00 shipped. Also ordered the drive shower kit for it as well.
