pine island fred
Thread starter- Joined
- Dec 20, 2002
- 1,144
After repeateted oil/filter replacement to eliminate water in crankcase, friend took boat on a trip today. Engine developed a loud knock that from me standing in the water could be either a bad bearing or hopefully a bad lifter. Did not want to get any closer at this point. <br /> Question is , can the lifters be replaced without removing the heads? Did this on a chrysler slant 6 with a tool I have. Dont know if the push rod hole is large enough on a chevy 305. <br /> Also, if the block is trashed can the engine be replaced without removing the outdrive? Boats is in the water, no trailer but on a lift. It is a 92-93 chaparrell with a volvo 290 DP with a small block chevy 305. When do you know when to stop throwing $$$s at these things? thanks fred
