Mark42
- Oct 8, 2003
- 9,334
I want to slow the poly cure time to get another 5 or 10 minutes working time. Did some searching in this forum and found this thread that addressed slowing cure time:
http://forums.iboats.com/showthread.php?t=219539
My question is how much to adjust the hardener for about 30% increase in cure time?
Using Bondo (3M) brand resin with a working time of about 12 minutes. The mix ratio is 0.37 oz hardener to 29 oz resin. That makes a ratio of 1.2% (0.37 / 29 = 0.012). To get another 10 minutes cure time at "room temperature" should the ratio be changed to about 1%?
I see where ondarvr said not to go below 1.2% due to strength loss, but in this application, strength is not a big issue, and neither is water proofing. I'm working on the windshield frames, which are above the water line, and will be painted. Any extra strength added to the plywood is a plus.
I usually speed up cure time, not slow it down.
Any advice is appreciated!
Mark
Mark
