nhmtnlaker
Thread starter- Joined
- Jul 26, 2006
- 8
New to boating have 87 chapparral 195 / 200hp. Boat is slow to plane, especially with load. I have 21 pitch prop, should I change?
vacayooper said:Make sure the boat is loaded correctly, the engine is tuned up and the filters and fuel are fresh. I made the mistake of easing up on the maintenance of my boat and had a miserable time looking up at the sky while starting out. A new fuel filter, cap, rotor and serviceable battery later that problem is gone. There are plenty of 4 cylinder boats out there performing just fine but you have to take it for what it is. If you are boating up at a high altitude you generally loose 20 % of your performance, going numerically lower on the prop helps out but make sure you stay in your engines rpm range.
QC said:Welcome to iboats nhmtnlaker!!
Well first we'll need some more info to help.
1) Do you know what the RPM is at wide open throttle? Need to know what RPM the engine is at when operating as fast as she will go with an average load and trimmed properly. Check here for more info:
FAQ WOT thread
2) 200hp what? I/O? Make model year all the stuff
3) Have you ran a boat before? Define long time to plane, more than 10 seconds?
4) Where do you boat? Altitude?
5) Do you know any history of this boat?
Basically we need to know if it is running correctly now and some other specifics before we can determine if it is right as is or needs some help.
