ehenry
Thread starter- Joined
- Jan 6, 2002
- 2,393
Gentlemen, I have a 14' Monark flat bottom aluminum boat (sorry I dont know the weight) powerd by 2003 Mercury 25 horse classic two stroke engine. The problem I'm having is the boat is slow to plane and will not reach WOT which I've read in these forums is anywhere between 5500 and 6000 rpm's.
With just me in the boat and a 6 gallon tank of fuel, its slow to plane and will only reach about 4500 4800 rpms. I've moved the trimi bar to its lowest setting and theres not much change. Lord help me if I put a standard size (185 lb) friend in the boat along with a 50+ lb cooler.
The prop thats currently on the boat is a Mchigan Wheel. The specs on the prop are: DIA=10 3/8 PITCH=13 . Its a 3 blade prop. I would like for the boat to plane quickly, run with a 300 to 500 + lb. load and reach WOT or somewhere close to WOT.
Also, I understand if I want to stay with an aluminum prop or go with a stainless prop pitch and size may differ. Stainless recomendations will be welcomed.
Thanks for your help.
