Slow Speed???? Johnson Seahorse 4 1981
debnjit
Johnson Seahorse 4 (27cc) Model J4BRCIC serial number B006466 (1981).
There is a question on the front of the engine with a dial/knob.
Slow Speed, lean or rich? Can anyone tell me what to set this at? Or what it means? I have no manual. The previous owner says the book was eaten by mice!!
tashasdaddy
Re: Slow Speed???? Johnson Seahorse 4 1981
if this does not cure your problem, you may need a carb cleaning and rebuild.
(Carburetor Adjustment - Single S/S Adjustable Needle Valve)
(J. Reeves)
Initial setting is: Slow speed = seat gently, then open 1-1/2 turns.
Start engine and set the rpms to where it just stays running. In segments of 1/8 turns, start to turn the S/S needle valve in. Wait a few seconds for the engine to respond. As you turn the valve in, the rpms will increase. Lower the rpms again to where the engine will just stay running.
Eventually you'll hit the point where the engine wants to die out or it will spit back (sounds like a mild backfire). At that point, back out the valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest slow speed setting.
Note: As a final double check setting of the slow speed valve(s), if the engine has more than one carburetor, do not attempt to gradually adjust all of the valves/carburetors at the same time. Do one at a time until you hit the above response (die out or spit back), then go on to the next valve/carburetor. It may be necessary to back out "all" of the slow speed adjustable needle valves 1/8 turn before doing this final adjustment due to the fact that one of the valves might be initially set ever so slightly lean.
When you have finished the above adjustment, you will have no reason to move them again unless the carburetor fouls/gums up from sitting, in which case you would be required to remove, clean, and rebuild the carburetor anyway.
tx1961whaler
You didn't say if the motor was running or not. If it's running OK, don't mess with the adjustment. That knob sets the slow speed idle mixture. If it's adjusted wrong, then the motor won't idle.
coolguy147
mice@@@ hahaha:D
and at idle just a little check make sure its not giving u a sneeze and if u floor it there shouldnt be any hesitation for exmaple u floor it it wont go then bam its gone like that
