Slow recoil on Johnson 4hp Cord
mdking77
I just took a Johnson 4hp (not sure of the year) out of my Dad's basement; hasn't been used since 1993 I am guessing. It does start, but the pull cord is very slow to recoil. Any suggestions?
1946Zephyr
Re: Slow recoil on Johnson 4hp Cord
Yep, spray the heck out of the assembly with WD-40 I'm sure that you'll need to do a lot more, once you get it to start.....and that's if you're lucky enough to get it started. At the very least, it'll definately need a new waterpump impeller and likely the carb and ignition system will need going through. Good little motors and well worth the effort. A have a comparable model in the Evinrude here and they run nice.
