I have a 1986 Evinrude 70 hp with the same problem, boat was in the water, I flood it right off the bat and cranked and cranked until the battery died....replaced the battery (tried 3 different batteries) and tried to start it but now it cranks to slow to start. The battery is almost 13 volts fully charged, while cranking I'm getting 9.4 volts or better at the starter. I put a rope on the flywheel and can't seem to pull start it due to the compression being good. This weekend I will be trying to check the compression. I have also removed all the wires I can find and cleaned all the connections as another forum suggested. Please help!!! I want to go fishing!
