Cranking speed is slow, will hardly turn over. I checked the battery voltage at 12.67 volts. Used jumper cables to short across starter, it turned fast, also jumped to hot side of solinoid and grounded to motor, also turned fast. The battery connections look o.k. also if I jump from my trolling motor to cranking motor battery it will spin fast. Battery is new, less than 3 months old. Any suggestions?<br />Thanks, Ed
