Kirschking
Thread starter- Joined
- Jul 22, 2017
- 4
Bought it used trying to get it running.Good compression on all 4 spins easy by hand with plugs removed. When I got it starter would barely turn motor over with plugs in spun fine removed. Brand New starter and brand new battery first 2 turns of fly wheel very slow then picks up a little and fires right up.
*Note I do not have a key I disconnected the black/yellow wire on ignition switch and jumper cables direct from battery hooked to the starter with positive cable hooked to wire coming from starter where it bolts onto a solenoid or something
Is there a compression relief valve that's supposed to open when starting
I don't know where to look next any help greatly appreciated
