Slow at full throttle
bhaut
I have a 1975 Johnson 35 hp outboard. Most of the time the engine runs great. However on occasion the engine seems to "bogg" down. I will be running fine at full throttle then the RPM's and speed will be cut WAY down and I get a strong smell of gas. Sometimes it will completely die and others I can run at about 5 mph to limb back to shore. A lot of the time the engine will start back up and run just fine. Any ideas at all!!
OBJ
Re: Slow at full throttle
Hi bhaut...welcome to the iboats forum...<br /><br />Being a 75', do ya' know when the last time the carb was overhauled? Give this a shot, next time the old girl gets a tantrum, squeeze the primer bulb and see if she picks back up. If she does, may be the carb needs an over haul. If the gasket between the carb main body and bowl is black, then I would say a rebuild is needed. The newer gaskets are a brownish color. They are made from Vitron which is supposed to be resistant to alcohol gas.
bhaut
Tried pumping the primer, it is rock hard and no change. Last weekend she was running great then died suddenly and has not started since. The plugs are sparking and the she is getting gas. Someone mentioned the points to me, any possibility this could be it? Also, once I get to them how can I tell if they do need to be replaced. Thanks!!
