charliegiggles
- Oct 19, 2006
- 50
Hi,
I have a 1973 40HP evinrude on a 16.5ft Starcraft Holiday aluminum boat. I just bought this boat and took it out for a test drive. It seems to idle fine and sound fine "loud" at WOT.
The boat however appears accelerate ver slowly and I'm thinking the prop is finshed. It sounds as if someone is sucking air through a straw when I'm accelerating and the prop does not appear to be engaging properly with the water. I can barely get a fishtail to appear and this only after a minute or so at WOT.
The propeller does appear chipped "not drastically" and I'm wondering if the fact it's chipped could create air pockets and prevent the prop from engaging properly with the water. I checked compression on both cylinders which were about 110 on both and both spark plugs appear to be operating properly from looking at them. IE light carbon build up and proper gap. The boat is rated for an 85HP Max motor. My friend has a similar aluminum boat with a newer 40HP and his flies compared to mine.
Is there something else I may be missing?
Thanks for your help. Much appreciated.
