Slipping prop
Wetwilly62
I have a 1999 mercruiser 5.0 alpha one out drive, prop is slipping , factory aluminum prop, looking for replacement hub , the inside looks like a tapered stepped cone it does not resemble the flo master 2 . Any suggestions..
Chris1956
The older props had a pressed in hub. A prop shop was the cure, when they went bad.
