fabguy5000
Thread starter- Joined
- Jul 25, 2007
- 5
Ok I know it is not a slipping clutch but that is what it feels like when I try to push the throttle up to higher rpm it feels like the clutch is slipping. The boat slows and the rpms go up as if it is a slipping clutch. The prop is tight on the hub I have already checked that. Also the thing has no reverse. The safety thing on the transome is broken but the reverse should still work if the little rod is held up or down you tell me. Maybe these two problems are related?? It just started slipping but the reverse hasnt worked in a while. Any help would be appreciated!! I can fix just about anything if I know where to look so hopefull someone can point me in the right direction. Thanks. Bob.
