Slinger installed inside pump housing
kary8285
I recently replaced the water pump on my 1991 150 Mariner. I installed the slinger inside the "groove" in the upper housing. I've since read the slinger is supposed to go on top of the housing. Will the pump fail if I leave it this way, or do I need to pull the lower unit and change the slinger location?
Gee, I would think the slinger would distort the upper pump housing over time. It might even crack the upper case. There is also a groove which helps the pump prime. Maybe the slinger cloggs this?
I would pull the gearcase and fix it.
kary8285
I pulled the lower unit today and installed the slinger on top of the housing. Not sure why, but the old water pump didn't have a slinger. Thanks for your response.
Dukedog
some leave it out for whatever reason.. usually see it layin' on tha bench "after" gear case has been installed.. been lottsa debates 'bout its effectiveness......
kary8285
I've owned this motor since new in 91. The water pump was replaced by a dealer in Wisconsin about 12 years ago - went out while on vacation - so they left the slinger out. It wasn't difficult, other than lining up the coupler for the shifter when reinstalling the lower unit, so I think I'll replace it more often to avoid a failure.
