PiratePast40
Thread starter- Joined
- Mar 21, 2009
- 1,734
The upper gearbox is off the outdrive and discovering a little play in what appears to be the gearbox itself. When I hold the u-joints and rotate the shaft back and forth, can feel about 1/8" slack. I've tried this with the shift lever in all three positions and still get the same thing. It doesn't appear to be the u-joints and looking at the diagram, it appears that the next bad actor would be the gearset. That certainly doesn't sound pleasant from a financial viewpoint. My questions then are:
1) What amount of play is acceptable?
2) What are the likely suspects for the cause of the problem and of course, what is the recommended resolution?
Thanks
Thanks
