I_5320
Thread starter- Joined
- Jan 3, 2011
- 59
Hello all,
Trying to zero in sizing my prop in completed Project Boat.. I?ve done some homework and some initial field testing.. Overall goal is hoping I can get this 50 hp to perform well enough to stick with it and not be tempted to up the HP.
Motor = 1980 Merc 50 HP Tiller (Canadian version if that makes a difference)
Boat Hull = 1985 Sylvan Super Sportster completely modified into fishing boat
Boat & Motor weight = 1,450 lbs.. Incudes everything on except fishing gear;
RPM Range = 5,000 -5,500
Gear Ratio = 1.83 (double checking this)
Weigh distribution = 12 Gal Gas tale in the Stern,, 3 Battery?s under fron deck platfom . ? plywood Deck
Current Prop = 10 3/8 X 14 3 blade Alum Merc
Prop condition = Blades look like they?ve been ground previously a bit and has lots of nicks.
Motor Height = Cavitation Plate 1 inch above bottom of hull. Was told this is just about right for this boat Appears not to be cavitating at all.
WOT Test = 4,950 RPM with me and 1 other 160lb passenger
Speed Test = No Speedometer and forgot about using GPS
Problem Symptom = Hard to plane with 4 persons.. Not as fast since I added all the crap.
Where I?m at:; = Bought a 10 3/8 X 12 Vortex 3 blade.. Was thinking to get close to 5,400 with me alone.
Questions.. Knowing how to rig up a shop tach now I can go it alone.
1 .Is goal to get as close to 5,500 RPMS as possible with just me and a light load?
2. Also ,I?ll be sure to check speed (with trim at optimum) when testing the 12 pitch.. Anything else I?m missing?
3. Last, is 10-11% slip considered good/normal? .If so is my math is right and the best I could expect with this motor/boat setup is about 30 MPH?
Mark
Mark
