Size of Circuit Breaker
mailman55
What size (amp) of circuit breaker would you want to use for a Minn Kota 12V. 55# Terrova to be on the safe side? I realize that too big of a amp.setting might do as much damage as too low. Thanks
Silvertip
Honorary Supreme Mariner
Re: Size of Circuit Breaker
60 amp. The motor draws a maximum of 46 amps so you might get by with a 50 but that would cut it really close.
jlinder
Remember that you want to make sure the wiring also supports 60 amps.
