Hi all,<br /><br />I am in the process of replacing the flooring in a 25' cabin cruiser.The boat is a 1957 model and over the years has developed areas of leakage. Whilst tearing out the flooring inside the boat, I saw that the center stringer had some rot. This stringer is a 2X6 that is tabbed to the hull with fiberglass tape extending upwards about 2". This 2" barrier has prevented water from contacting the wood. The top 4" (about 18" in length) however, is rotted away from water leaking in from the flooring topside. I have two places in which this situation has occurred. Access to this stringer is very limited. The dinette table seating assembly sits next to this area.I really don't wish to remove this as it would be a very labor intensive job. I believe that I can have access to the stringer however, if I cut out some of the flooring. Doing so would allow me to install 3/4" plywood stringer sisters on both sides of the damaged stringer.<br /><br />The rotted portion I intend to remove and fill with 2X4 that has been firstly encapsulated with 2 to 3 coats of thinned epoxy resin. This plug will be bonded to the stringer with a peanut butter resin and fiber mixture and will be located between the sisters. What do some of the more experienced ones think of this approach?<br /><br />Thank you.
