Single solenoid trim pump wiring?
Status
Not open for further replies.
aroncornell
Ok so when I got this boat it would trim down but not up. When I try to make it go up no clicks or noises happen. I am able to use a jumper to put power to the up terminal on the solenoid and it works great. So that's problem no one. No two is there are a blue wire and a purple wire coming out of the transom and then a blue and purple wires coming from the pump wire harness but these two have female bullet connectors on them. I tried hooking them together blue to blue and purple to purple but still no up trim. Any suggestions???
Don S
Re: Single solenoid trim pump wiring?
Here is the diagram.
aroncornell
Thanks Don. That's exactly the diagram I needed. So if everything is wired correctly. What could b my problem?
Don S
Does it come up if you push the center and top button at the same time?
aroncornell
No, I tried pushing the top 2 together and nothing.
Don S
I found my wiring diagram too. Much easier to follow.
I assume when you jumped the solenoid terminals, you jumped the two large terminals (A and C in drawing) to make it work.
Try jumping between A and D and see if it works.
Also, using your volt meter, put your black test lead on B and your red test lead on A. You should show battery voltage.
aroncornell
Ok I tried connecting a and d and nothing happened. I don't have my meter so ill have to tes the voltage tomarrow
Don S
If A and B voltage is ok, then you need a new solenoid. If it shows no or VERY little voltage, you have a bad ground on that black wire .
aroncornell
OK, so i replaced the solenoid, and it works!! i think. lol It goes down with the bottom button, and i have to push the top two buttons for it to go up. Is that just the way its supposed to be by pushing the two buttons for up, or is something else broken.
Don S
The trim limit switch is either inop or way out of adjustment.
You should be able to trim up around 15 to 20? with the center button, then use both buttons to raise it all the way up for trailering.
You can either bypass the limit switch and use a single button for everything, or fix it.
aroncornell
ok, id like to bypass the limit switch, how would i go about doing this? i didnt even know there was such a thing on a boat, where is it located?
aroncornell
easy enough. thanks alot for all your help
Status
