Single long tone Warning
JustAddWater
The last 2 times I have been out I have tried to air out wide open trimed to clean out the cobwebs and my check engine light and single tone warning has gone off. Boat comes to an idle and I turn it off for a minute or two. It will resume to running if I don't go wide open. I had this problem before and changed water pump and thermostats with OMC parts. Motor is pumping good water pressure and was never hot. Only happens with a few minutes of wide open. 1999 Johnson 150 Ocean Runner with approx.70 hours on a complete overhaul. This engine looks like the day I got it. I don't have vin# handy, but looking for some advice. Thanks in Advance.
Cricket Too
Re: Single long tone Warning
JustAddWater.....Welcome to the post. Have you checked your oil resovoir for low oil? My boat has given me a long alarm when my oil gets low and it has always happened at WOT. There are different tones for different things and even though the long loud tone is usually overheat, on my boat it is low oil and the low oil light comes on also, so check your oil and see what it looks like. Good Luck.
seahorse5
On a carb motor, the check engine lite can only mean a fuel restriction, probably in the boat system. Most common culprits are internally collapsed or kinked fuel lines, plugged filters, trash in the tank pickup screen or tube, and faulty anti-siphon valves. If you have a fuel selector swtitch for mulitiple tanks, it may not open completely or may have to small a passageway inside for the fuel flow. You need to use 3/8" fuel lines and fittings with a 9/32" inside diameter minimum.
JustAddWater
My oil resovoir was 1/4 full yesterday, I'll fill it up to see how that acts. I'll check the filters and gas lines also. Thanks Guys.
seahorse5
IF that alarm and check engine lite comes on again, don't run the motor for long as you are leaning out the mixture with the restriction and that can ruin a piston very quickly. Dont forget to check the venting of your gas tank, too.<br /><br />If your oil tank is getting empty, then the LOW OIL lite will come on, not the CHECK ENGINE lite.
