simple starter wiring
suseejr
I have a 14' starcraft 1961.The key switch is gone.All the wiring is gone.I use the pull starter and it runs fine.I just want to hook up the starter and see if it works.What's the best way without speding a ton.I have the junction box and the starter solenoid.Thanks
brianvolt7
Re: simple starter wiring
Get a simple key switch or push button that applies momentary (resets on its own) voltage to the starter solenoid. Don?t forget you need a way to turn it off also.
