Simple question...... I hope
viper1
Is a 2010 3.5 Nissan 4 stroke long shaft A big enough kicker motor for my 1987 Starcraft Islander? Jus want to troll with it 2-3 MPH
82rude
most if not all the guys I know that have islanders have 9.9 or 15 hp kickers.with 15 hp being the more prevalent.that little Nissan will have a hard time getting you out of trouble.
Sea Rider
Better go minimum for a Nissan/Tohatsu 9.8 kicker, portable enough and with punch. A 3.5 is too basic, will take you there provided that water is near flat, non windy and without strong currents to deal with.
Happy Boating
without wind, yes, with wind probably not.
ondarvr
Also the small single cylinder 4 strokes are very annoying to troll with, they are louder and tend to vibrate much more than a larger 2 cylinder motor.
viper1
Well I got a Yamaha 2 stroke 8 hp I can use. Just figured a four stroke could run off the same tank and not need an extra tank. Also the speed and steering controller's are all made for a 4 stroke for some reason. May just go with a steering link and leave it at that. Least until I can afford a minn kota 101 with I pilot. LOL! Just trying to think it all out till i can actually do some thing when the weather gets right.
airshot
I have a 22' Islander with a 9.9 which works great, your 8 hp will work but that should be minimum, the 3hp will be disappointing at best. Any wind at all and you will be going the wrong way. If it were a sail boat model you could get away with it as they are geared differently and propped different to push heavy loads but a standard 3hp would be to weak.
Sea Rider
Those Nissan/Tohatsu 3.5 HP comes with standard delivered props, if wanting to push heavy loads as sailboats more efficiently will need to change prop. That's on the 2 stroke models, probably same on the 4 stroke ?
Happy Boating
viper1
Well Just a thought. Had a good deal on one so I was wondering. Guess i'll keep my Yamaha 8HP tiller. 2 stroke. Will hook it to main motor. Would be nice if i could control the throttle from the captains chair. But I see there all made for 4 strokes. Since its just for trolling guess we will just pull start and adjust speed at the motor.
