Signs of bad compression
BASSNSNOW
my 115 merc runs fine top end @ just under 60 mph, but it stalls when going from neutral to gear and it has a rough low rpm i was just wondering if this is one of the signs of poor compression :confused:
Fouled Plug
Ensign
Re: Signs of bad compression
Depending on the hull, if you're going close to 60 I think the compression may be OK. Could be in need of new plugs and a tune up. Start with the basics, and get a compression gauge. Cheap troubleshooter, and very handy to have around.
my new fishmaster
Its the fuel delivery check out your fuel pump replace with a rebuild kit for $12. New fuel filter and could be the bulb pumper thingy.
kev_79
What year model? If it's a 4 cylinder, it is a 2+2. Check idle air screws on top two carbs, right side looking down the throats. Adjust them to 1 1/2 turns out from set. Also, a can of power tune couldn't hurt. Good Luck
12Footer
And if it is the V6,check the low speed winding of the stator.
kev_79
Also, I was wondering, what kind of boat and prop you are running. That is a pretty good top speed. I am running a 115 on a fairly light bayliner 18' and I can only get close to 45 with a 21 pitch prop. I am trying to figure out if my prop is slipping a little.
OBMD
How about doing an actual compression test? Do one every year as a base line for future reference.
BASSNSNOW
got my compression checked and it was good all 4 cylinders were at about 12o. so i guessing it has to be the fuel delivery system also it had a good strong spark is this a good assumption ;)
hondon
What altitude are you running at?
