should the engine turn
not2high2fly
I'm in the middle of a bellows,shift cable job on a 84 4winns santara with the 898 engine. My question is since i put the boat in forward and removed the shift cables to remove the out drive will i still be able to turn to engine over by hand (breaker bar on crankshaft nut)? Thanks
havasuboatman
Ensign
Re: should the engine turn
yes, Shifting takes place in the outdrive, if you are doing a bellows and shift cable, your drive isn't connected. You shift your drive into fwd to align the shift linkage couplers
180shabah
With the drive removed - the only thing you wil be fighting is engine compression.
drrm123
You can remove the spark plugs if you dont want to fight that. LOL
Bt Doctur
Why would you want to do that?,and using the nose bolt it can break .
you can still use the ign. key for that.
If your worried about spline alignment, we usually lube the new impeller, shift drive into fwd and ocking the prop CCW, and turning the prop CCW to slightly turn the drive shaft to line the splines up .
